AT91SAM7S256-EK programming reset problems
I’ve been programming this board for servals mounths with Eclipse +openocd+wiggler.
Some time ago, durning normal work when everything goes ok, one error occured :
“arm_7_9_common.c:563 arm7_9_execute_sys+speed(): timeout waiting for SYSCOMP & DBGACK, last DBG_STATUS: 1”
And after serval second the programming process stops.
But if I comment one line in script.ocd regarding user reset enable :
“mww 0xfffffd08 0xa5000401 # enable user reset AT91C_RSTC_RMR”
programming proces is ok, but i’ve to reset my board by unpluging power.
I think that its some problem with reset controler.
I’ve tried programming my board by H-flasher with the some result.
Also erasing Micro… by erase jumper didn’ work too.
Could You pleas help me with this problem?
Lukasz.
