I believe this may have been discussed somewhat before here, but I didn’t fully follow:
http://www.mail-archive.com/openocd-dev … 13001.html
I am hoping someone wiser in OpenOCD will know.
I have a LMS9B92 dev board. Chip is rev B1. I am using the provided “ek-lm3s9b9x.cfg” script (I have an ARM-USB-TINY but am using the supplied FTDI JTAG with the board).
“reset halt” fails with timeout error… expected return code but got ‘TARGET: lm3s9b9x.cpu - Not halted’
“halt” command seems to work in order to prepare it for flashing, and flashing seems to work
If I comment out the last line:
#LM3S9B9x Evaluation Board has only srst
#reset_config srst_only
“reset halt” does not return an error.
I would like and information on: if there is any negative effect known in commenting out this line, what the details are on the soft-reset only requirement, and if the the trunk was patched with the code in the thread I mention.
I tired posting this to the OpenOCD dev mailing list but it just rejected it the first time and later told me I was not allowed to post at all. I find that very odd…
