ATmega 328 programming.
Hi! I have bought an atmega 328 with uno bootloader and also a shifter board kit. My question is how i can connect them to put sketchs with arduino IDE.I have use this site(http://www.jameco.com/Jameco/workshop/J … rcuit.html) to put atmega on a breaboard but is there any way to use the shifter board(https://www.sparkfun.com/products/133) to run codes on atmega?
Uhmmmmmmmm…what? Huh???
2 ants, a fartscicle, blue, and yugglesmaf.
dimi154:
You mean to upload sketches? If so, I wouldn’t buy that. The easier way is to use this, https://www.sparkfun.com/products/9716
Note - no matter how you look at it, you are going to need more components on the breadboard to program the ATmega chip.
ok thanks! But what compoments i will need? And also how i can connect the ftdi board to atmega 328
Google has all the answers you seek.
dimi154:
Buy one of these and get on with it
http://www.pjrc.com/teensy/index.html
SFE sells some but not all options in PJRC’s products
Some of these are mega32 USB built-in; some are newer/better ARM Cortex M3 with gobs of memory/flash and a simpler single address space. Both have the Arduino libraries, even the ARM board.
See the forum. You can’t fail with help like the forum users offer.
