Base Facet to Rover Facet 915 mhz radios
I bought 2 facets and a LoRaSeriel radio kit. I have one facet set up as base and the other as rover. I’m trying to get the base to send rtcm over the loraserial radio to the other rover facet.
I’m trying to survey with the rover. I can get rtk fix, then as soon as I start moving the rover it goes to rtkfloat… I’m questioning if my 915 radios are working properly
https://docs.sparkfun.com/SparkFun_RTK_ … base/#mode Is the base set to survey-in mode? (you can also do a long-term survey and use fixed mode if you’d like)
Yes, I can get rtk to the rover. When I have the radios hooked up, the correction alternates between dgps, float rtk, and rtk. When I unhook the radios I get rtk.
Are you still having this problem? If not, what was your resolution?
I might be having the same issue: viewtopic.php?f=116&t=
Are you still having this issue? I submitted an issue to the github firmware repo.
https://github.com/sparkfun/SparkFun_Lo … issues/587
