RTK Facet NTRIP CASTER AND SURVEING MODE
i’m sorry but i really need your help, i’m trying to start the rtk facet into base mode, but it didn’t work, cause it did not go into Survey in mode , can anyone help me please?
I’m using the latest firmware v 2.5, rtk facet L1/L2.
Any suggestion would be appreciated. :roll:
P.s. I would like to know if any of you have information on the possibility of sharing the data correction locally via wifi.
The Facet will turn on and display ‘Rover Started’ or ‘Base Started’ at power on. The unit will remember the last state it was in (base or rover) and start in that state at the next power on. You can switch between Rover or Base by pressing and releasing the Power button.
Display information is here: https://docs.sparkfun.com/SparkFun_RTK_ … /displays/
Configuring the base setup can be found here: https://docs.sparkfun.com/SparkFun_RTK_ … gure_base/
