It seems that now I having problems uploading a zip file to BatchPCB for crc checkup. I getting the error as following
Zip File Pre-Processor (Step 1 of 3)
Array ( [name] => SLB.zip [type] => [tmp_name] => [error] => 2 [size] => 0 ) Error : PCLZIP_ERR_MISSING_FILE (-4) : Missing archive file '/home/.sites/33/site5/zips/1170351515/1170351515.zip'
I guess BatchPCB is down for a while…
Shane
This problem has not yet to be fixed. Does anyone else having problems uploading zips?
Works for us in house.
I’ve also seen tons of other orders go through since thursday when you first posted.
How big a zip are you trying to upload?
Cheers,
–David Carne
busonerd:
Cheers,
–David Carne
Well, it can’t be me for sure, I have try zipping them with WinZip as well and it still fails to find the zip file on the remote server. The file is only 1.20 MB. I mean this was working before and I not changed anything and it now fails.
Update: I have try uploading a fake zip file and it works fine, but for some reason it won’t upload files that is a 1 MB, how can I upload this then?
Wow…my zip files are usually around 30-40 k…I don’t know what you are including…but that must be the problem.
Hmmmm…I think that would be the problem…the size.
James L
I’ll check the upload quotas on the server.
Why is your gerber file that big anyhow?
Cheers,
–David Carne
busonerd:
Cheers,
–David Carne
Beats me, the board is 260.69mm x 223.51mm which include alot of small PCBs on it. I found out that my PLC file is HUGH is around 8,333K. I guess I have to show you what the board looks like.
