Battery Babysitter load with Solar
Hello
on the Battery Babysitter Battery Charging
https://learn.sparkfun.com/tutorials/ba … y-charging
it is possible to connect direct a Solarpanel?
Leistung: 2W
Spannung: 6V
Max Strom: 0.33A
it is a small thing
have a nice day
vinc
As long as your solar panel doesn’t exceed 6.4 volts, you should be OK. You will also need to configure the Battery Babysitter to charge at 100mA, the other settings are more than your panel can provide.
