Solar Panel and Battery Babysitter
Hi there,
I’m using a Sparkfun Battery Babysistter with a Particle Photon.
Everything works like a charm and I use and USB cable to charge the battery.
Now I want to recharge the battery, through Battery Babysitter, using a solar panel. Is this possible?
Can I connect a solar panel to Battery Babysitter Vin?
Thanks for the help!
Best regards,
Federico
Hi Federico.
You will need a 5 volt regulator between the solar panel and Battery Babysitter, but once you have a regulated 5 volt supply coming from the solar panel, you should be good to go.
Hi Chris,
thank you for your reply.
Should I use a diode ( on the Vcc wire) between the solar panel and the voltage regulator?
Thanks for your time.
Best regards,
Federico
I don’t see why that would be necessary.
