I have the Beefcake Relay Control Kit # 10733. When I was reviewing the “assembly” instructions, I noticed that my PCS does NOT look like the ones shown in the photos . The placement of the resistors, and transistor are not the same.
Can I post a photo here and have someone review this PCB BEFORE I ‘start’ the assembly and soldering process.
Not sure where you found this, it’s a super old version that was discontinued 10 years ago. There never was a guide to put it together, you just followed the silkscreen to figure out where to put components.
Mike is right, this is OK for low voltages, (24 volts or less) but not safe to use with AC mains voltages.
TS-Chris:
-Not sure where you found this, it’s a super old version that was discontinued 10 years ago.
I guess you can call me the “King of Procrastinators” . I bought this kit, then retired, moved 3,000 miles, and now I’m just getting my soldering station up and running.
Last time I checked, solder does NOT go bad . (Maybe Flux does.)
-There never was a guide to put it together, you just followed the silkscreen to figure out where to put --components.
I will try to follow the link, but this “still” does NOT look my Beefcake relay control kit # 10733.
-Mike is right, this is OK for low voltages, (24 volts or less) but not safe to use with AC mains voltages.
