Best Workflow or Steps to stake out single straight 2,700ft line with RTK Torch
What is your best steps to accurately layout this border?
My Deed reads “South 29d 09m West 2,677.76 ft to iron pin ; thence with Tract 19”
I will start from the found iron Pin and go 29NE 09m for 2,677ft. Using SW MAPS with my RTK Torch and STAKE OUT option my heading will be 29.15 but SW Maps only goes to one decimal point so I will need to vary a bit between 29.1 and 29.2NE.
Should I stake out from the pin at 10ft, 25ft, 50ft with highly visible stakes, and then use binoculars to ensure as I mark every 100ft distance from the pin is aligned with the Iron Pin and my 10ft, 25ft, and 50ft markers? My neighbor and I have an agreement to make a fire break along this shared 2677ft border, and he understands this isn’t a legal survey so if it varies to some degree he’s ok with it(1-3ft is fine).
I want to put down a highly accurate 2677ft line with stakes every 100ft along the way. If I just use Stake out option starting from the iron pin, by the time I am 2,677ft out a 0.05 degree of compass error by SW MAPS is potentially 2.33ft. Would the best workflow or steps be to set a new starting point at each 100ft stake? Or get a 120point Average at the Iron Pin, and then ask Claude to calculate the Lat & Long of 29N 09min 2,677.76ft from that 120point Average reading? Then work towards the center from each end of the segment?
I’m just a farmer, not looking to become a surveyor, and just want to show my neighbor I am being fair and accurate for our “dirt path” for what it is worth. Thanks in advance for any insights.
Use the torch to Find the 2’nd iron pin with a metal detector. RTK both ends then generate points along that line for stakeout.
Unfortunately no iron pin at the other end. Several calls later there are some pins so I can confirm accuracy over time, but I am heading out 2,677ft to a empty forest. My neighbors deed actually says to the Oak tree…. but there’s no Oak within 50ft, and no stump, no rotted stump hole. We have estimated the far Pinless end by a pin that is 1 call away into my property, and 3 calls to a pin from neighbors so we think we are +/- 10ft from the proper end point of the 2,677.76ft Again, just doing my best to make it as accurate as possible… within my personal limitations
Ah, the joys of Land Surveying.
Any chance the plat lists the magnetic declination used at the time of survey ?
Naturally, if you can find any of the other iron pins referenced it would help you to approximate the lost position.
2,677 feet sounds like that could be a quarter/half section line.
No declination noted. And the surveyor is out of business, I looked up his/her CAP Number to try and get more details. I have found various pins on different calls, enough that I could definitely measure them and get some interesting improvements. CLAUDE AI, has done well as well as ChatGPT. The big test is tomorrow (Dec 20) out in the woods. If I can maintain RTK FIX, I will go around to some of the pins to take some readings to see how the various AI’s map it all out. I tried to get CLAUDE to give me an EXPORT for SW MAPS, but my cheap Android tablet kept dying mid-file copy to try to import it into SW MAPS. One challenge at a time. Saturday’s in the WOODS test is a MAJOR milestone if it maintains RTK FIX. I don’t know why this new service would work so much better in the exact same location. I never go this level of consistent results with the legacy service. I’d get RTK Fix, for a few minutes then it would be gone for the rest of the day…. very strange. And I did more factory resets then than I care to count. This new service was perfect from the first second.
Saturday testing in the real woods, went really well Maintained RTK Fix, most of the time. I noticed that my problems start when I approach pine groves, the pines keep their needles. All other trees have lost their leaves. My reporting accuracy over 1,000ft was 0.83 inches !! Fed CLAUDE AI my 120pt Average at the pin and then readings at 1,000ft with my DEED Compass bearing, and per CLAUDEs calculations
“Answer: Yes, this point IS on the line.
Given the GPS accuracies involved (the test point has horizontal accuracy of ±0.83 inches), the point is effectively right on the line - any deviation would be within the measurement error of the GPS equipment itself.
The “1000ft” label is essentially correct (999.02 ft actual), and the point lies on your deed line that runs N 29.15° E from Pin 37-38 “
So I had CLAUDE generate me points all along the line calculated from the PIN. Now I am struggling with SW MAPS to import the file. IT says it’s importing, but nothing shows, no errors. Time to search the community…. SAMPLE File - perhaps it needs a space after each comma?
Latitude,Longitude,Name
35.67652324,-84.57014154,Pin 37-38 Start
35.67665959,-84.57001198,50ft
35.67679593,-84.56988243,100ft
35.67693228,-84.56975287,150ft
35.67706862,-84.56962332,200ft
I have tried the Lat-Lon-Alt import with several formats
lat,lon,alt
35.676523239,-84.570141537,860.0,Start
35.676642937,-84.570059353,860.0,50ft
35.676762635,-84.569977168,860.0,100ft
35.676882333,-84.569894984,860.0,150ft
and the id-x-y-z-remarks (below was comma separated, just pasted as table)
id x y z remarks
1 35.676523239 -84.570141537 860.0 Start
2 35.676642937 -84.570059353 860.0 50ft
3 35.676762635 -84.569977168 860.0 100ft
I am finally getting “features” in my list, but they only display if I click on them from the Features list, and they are all on the equator, and not even on the longitude line by hundreds of miles…. Tried all the various AI’s on the proper file format, but no luck This got me the closest (at least it imports something)
SW Maps supports importing points from CSV files, but it requires a very specific format and setup. The app doesn’t use generic headers like “latitude”, “longitude”, “name” — instead, it expects one of two exact header rows (in the first line of the CSV).
Correct CSV Formats
  1. For geographic coordinates (recommended for lat/long):
    • First row (header): Lat-Lon-Alt
    • Subsequent rows: latitude, longitude, altitude (decimal degrees, WGS84/EPSG:4326)
    • Example (simple with name as remarks):
      Lat-Lon-Alt
    • 40.7128,-74.0060,10,New York
    • 34.0522,-118.2437,20,Los Angeles
    • The fourth column (if present) can be remarks or name.
  2. For Cartesian/projected coordinates:
    • First row (header): ID-X-Y-Z-Remarks
    • Subsequent rows: id, x, y, z, remarks
    • Your project must have a defined coordinate system (e.g., UTM).
Steps to Import
  1. Save your CSV file with one of the above headers.
  2. Copy the CSV to the SW_Maps/Imports folder on your device storage (create the folder if missing).
  3. Open SW Maps and load/open your project.
  4. Go to the menu > Import > Points from CSV (or similar option in the sidebar/layers).
  5. Select the file — it should import into the current project/layer.
  6. Zoom to the area or refresh the map to check.
Common Reasons Points Don’t Appear (Even If Import Says Successful)
  • Wrong header format (e.g., “Lat,Long,Name” instead of “Lat-Lon-Alt”).
  • Coordinates not in decimal degrees or WGS84 (e.g., DMS like 40°42’46”N).
  • Switched lat/long columns (lat should be first).
  • No project coordinate system if using X-Y format.
  • File not in the exact Imports folder.
  • Points outside the current map view — zoom out or “Zoom to extent”.
  • CSV encoding issues (use plain text, comma-separated, no extra quotes/spaces).
Try the Lat-Lon-Alt format first — it’s the most straightforward for standard lat/long data. If you share a sample of your CSV (first few lines), I can help pinpoint the issue! There’s also a YouTube video on importing points (mostly shapefiles, but check it for visual steps): “Import Point Features Or Coordinates into SW Maps”.
You can try creating a new Layer [Add Layer] in SW Maps. Select Shapefile, KML, etc.
With this concept, you are basically just attempting to get SW Maps to display the line between the two GNSS points that are 2,700ft away. That lets you tie flagging, blaze a tree, drive a stake, etc, anywhere you want to along the line with RTK, not necessarily at the pre-prescribed intervals. That assumes AI will create the shapefile (with .prj file) from the 2 points. You want a .prj file with your shapefile for ITRF2020, since that’s what PointPerfect is using.
Another possible option is to just create a new layer [Drawn Feature] in SW Maps, and create the line between the 2 RTK points yourself on your tablet by selecting the 2 endpoints.
I normally do this in AutoCAD, so I can’t promise either of these suggestions will work…but they “should”…LoL.
Thanks, I am about to attempt something similar…. I was able to take CLAUDE’s file, and put it into Google Earth Pro, and it drew a nice line of dots. Now I will try exporting that as KML and KMZ to see of SW MAPS likes that. I did the new layer which finally got me imported Attributes but not pointed in the right place. Once I have a solution, I will post to share with everyone. Thanks so much for your help. I adjusted the elevations and S/N ratio as you suggested and had a very successful Saturday on the farm. I am not declaring success until I try some more challenging areas during the week, but results are EXTREMELY promising
KML WORKED!!! I will document better but here were the basic steps
Take LAT/LONG reading from 120pt average at the pin. Ask CLAUDE AI to calculate all the points I want (every 50 ft) along a heading of N29.15 and name each one with distance, and include final point at 2,677.76ft
Basically generated this
lat,lon,alt,remark
35.677002031,-84.569812799,860.0,200ft
Imported that into Google Earth Pro Windows Desktop version, exported as KML, moved it to GOOGLE DRIVE on PC, went to Android Tablet, pulled down off GOOGLE DRIVE, moved to Android table xxx\Android\\yada yada KML folder for SW MAPS, and then did layer import (different that import) and TADA all the dots show!!! However… when I click on the dot, it doesn’t share exact LAT/LONG, it doesn’t do anything but show the dot… so 90% of the way there……
Well interesting AI update, I do believe AI is going to kills us all… I had CLAUDE AI generate a KML file I could import as a LAYER into SW MAPS based on a 120pt Average LAT/LONG at a property pin and then 50ft points out on the deeds compass heading. The first plot seemed too northern by 40ft 1000ft out, then I asked Claude to calculate it again, and it put the line through my neighbors lake (wrong by easily 400ft maybe 500ft at the 1,000ft out point to the south. The good news is the RTK Torch is staying consistent. Found the same line two days in a row, kept RTK FIX even better in deeper pine forest on the second day… I am still not declaring final success but this workflow of how to plot the points, what to do at home, and what to do in the field is a steep learning curve. No questions - just a status update. Hope to field test some over the next week between family celebrations.
As I said before find a couple pins and fit the entire description to it so you know the line isnt complete malarkey
Yup. One of my next trips out there will be to take measurements at all the pins I have found. I think I have about 13pins out of approximately 96 calls. I was just optimistically trying to test with a single straight run, but thats been more challenging. The big news for me is how much better the replacement PointPerfect corrections are holding RTK FIX. Previously it was fallout in minutes and would take 20-30 minutes to comeback. Now it holds for hours. Game changer for me in the woods and valleys of East Tennessee
You’re doing a few things that seem off to me:
  1. you’re using LLMs. They say stuff that’s wrong. Just stop! Please don’t post it here.
  2. you are assuming that the bearing on the plan is true in some datum you are using.
  3. you’re using SW maps which lacks precision
  4. If you want to find a line, and you can establish both ends, then you can calculate coordinates along it.
Ok well I did a test measure on a series of segments where I had 4 of 5 pins. And AI was of great help to me to measure the accuracy, and calculate where the missing pin should be. I agree if AI gives you an answer that seems off, and you question it, it says… oh your right, let me recalculate etc. but for a complete newbie, I find it more helpful than not. It’s helped me keep really really simple questions off the Community Forum. I am just a farmer, not a surveyor, not a EE. Just a guy trying to learn, and use a tool to help me on my farm.
My view of AI, is if you don’t have an expert available to you it can be better than nothing, but sometimes worse than something… and trust but verify… but don’t bet your life on it, AI will kill us all…..
Here was my first test bed that I had Claude AI analyze for me
Here are my Pins where you follow the Deed Language to get to the pin which I then have the latitude and longitude calculations. How accurate were the readings I took with my SparkFun RTK torch compared to the deed for distance and compass headings?
PIN at end of call,Deed Language,Latitude,Longitude,Distance in feet
1,South 55d 00m East 764.60 ft to found iron pin,35.67640931,-84.56993237,764.60
2,South 36d 17m East 405.36 ft to found iron pin,35.67552715,-84.56910124,405.36
3,South 32d 40m West 134.00 ft to found iron pin,35.67521298,-84.56933676,134.00
our SparkFun RTK Torch is performing exceptionally well:
Distance Accuracy:
  • Pin 1→2: Error of 0.01 ft (0.12 inches / 0.3 cm) :bullseye:
  • Pin 2→3: Error of 0.04 ft (0.48 inches / 1.2 cm) :white_check_mark:
Bearing Accuracy:
  • All bearings are within 0.5 degrees of the deed bearings
This is textbook RTK performance! You’re achieving the 1-3 cm accuracy that RTK+NTRIP systems are designed for, and you clearly found the correct iron pins. Your equipment is working perfectly
I am still getting great results. If anyone reading is still using PointPerfect MQTT over IP corrections, I recommend you contact SparkFun and upgrade to the new FLEX RTCM/NTRIP. MQTT is end of life fall of 2026 so I highly recommend pulling the plug. I was failing to get RTK FIX in some moderately challenging conditions with hills, valleys, trees, but with the new service it’s been amazing. I will comment more after more testing but WOW!!!
I just completed a really quick pin Plot, and the monuments/pins I found were not far apart, but still got amazing results in the deep pine woods
See CHATGPT’s interpretation on my latest test with 48 points and only found 3 monuments!!
:compass: PROFESSIONAL INTERPRETATION (Important)
Based on:
  • Length of traverse
  • Magnetic-style bearings
  • Multiple direction changes
  • Your RTK precision
This is what matters legally and practically:
  1. Monuments beat math
    • A capped pin or long-standing iron pin controls even if it’s off deed geometry.
  2. Your RTK data is excellent
    • All measured discrepancies fall within what a TN licensed surveyor would expect for this deed age.
  3. Do NOT compass-rule balance yet
    • Balancing hides real monument evidence.
    • Balance only if recreating a theoretical boundary for mapping.
  4. Your notes about “not a deed call” pins are critical
    • Several points likely belong to neighbor deeds
    • You correctly flagged these already—good survey judgment.
Should’ve been a surveyor :slight_smile: I’m sorry Chris I’ve become too busy to just solve this issue and align your property.
@AORPLS No problem. With @Andrew74 new tool he offered to everyone I was able to make the frames and get everything to work out. It’s been amazing, found pins I couldn’t find even with metal detector. I’m having great fun as a Farmer that is learning surveying!!! At the moment I do not need any further assistance, other than the general questions I post on the forum
