Bi-Directional Logic Level Converter in parallel
The i2c Bi-Directional Logic Level Converter, can you use multiple channels in parallel to increase supplied current on the output?
Hi wizhippo.
The Bi-Directional Logic Level Converter wasn’t designed to be a current source and I don’t believe they will work in parallel.
What is it you’re trying to accomplish? There may be a different part or board that will work.
