BlueDongle + 6DOF v4 command issues
Hello, I am having some trouble sending commands to the 6DOF using the BlueDongle. They connect and I am able to send over and read certain commands but not others. Namely, none of the “shortcut” ASCII commands that alter sensor settings (like ‘+’ which sets freq. to 150) are registered. The way I am testing this is going into configuration menu and checking the current frequency etc. From there, I can up the values but it will take ages to get to 250 with +1’s.
Has anyone had issues with this? I’m sending over the ASCII char alone, as in ‘+’ not ‘+\n’ or ‘+,’ As mentioned, the ‘#’ and ’ ’ (space) characters work.
