Bluesmirf RN42 - RX voltage divider missing?
In the schematic of the Bluesmirf RN42 module there is no voltage divider for the RX port (only a 10K resistor).
Can you explain why that is the case as it does not match the RN42 datasheet specifications to provide a safe 3.3V signal to the RN42 unit? Or do I read the schematic wrong?
