BlueSmirf - USB cable replacement?
Hello all!
This is the first time I have started a post in this community, so I want to say hi to everyone! :slight_smile:
My real reason for posting, is to ask a question regarding the BlueSmirf. I just recently realized that USB only uses 4 wires to send signals. The BlueSmirf uses 4 wires to send signals. I have a robotics project that may be able to benefit from the ability to drop in a smirf instead of a USB cable. Can the smirf even handle this type of connection? Or is it only meant to handle serial cable replacement? Thanks in advance. Talk to you soon.
-Jay
RobotJay:
Hello all!
-Jay
Well, no you can't. The two specification USB and RS232 are not compatible. You would need a RS232 to USB converter to do that.
Jay
A USB host controller would also work. I think you might be able to implement USB using a UART, although I really wouldn’t know. I have also found a TI TUSB3210 that implements the functionality of a USB host, allowing communications from embedded systems to USB. Unfortunately, it also needs a program, in 8051 code, but I think that there are several reference programs on the TI website.
