Bluetooth range
Hello
Has anyone made range tests with the blueradios modules?
I’m especially interested to hear how long distances can be used between two modules with the chip antenna in open space. Also, how much would a better antenna in the other end increase the range?
Any experiences are welcome.
Regards,
vup
The Bluetooth modules have a pretty good distance of ~200-300ft line of sight. The MiRFs are slightly better, but the Bluetooth connection is rock solid.
-Nathan
sparky:
-Nathan
Thank you for the information. Anyone got longer distances? :slight_smile: I noticed that blueradios has a module with external antenna connector and they say: “The Bluetooth Male SMA 1/2 wave coaxial dipole external swivel antenna will provide increase performance +200 meters.” But I guess it’s only when both ends got a better antenna.
btw. Looking forward for those app notes.
Regards,
vup
vup:
sparky:
-Nathan
Regards,
vup
A better antenna on just one end would in fact increase range in both directions. A better antenna on both ends would increase it even more :)
NleahciM:
A better antenna on just one end would in fact increase range in both directions. A better antenna on both ends would increase it even more :slight_smile:
Yes, I would assume so. What I meant was that the +200 meters they state is given for a antenna pair.
Now I’m not sure if this +200 means “up to 200” or “more than 200”…
Regards,
vup
