When I try to provision my Blynk board and connect to its WiFi, I get the following message “incorrect password for BlynkMe-cccc” (and then it takes me to password page to type in the password). So I’m not able to connect the the board’s WiFi. Any help you can provide would be helpful.
Hi FNL,
You should not need to enter a password for the Blynk board during [provisioning. You simply need to have the most recent version of the Blynk app installed, scan the QR code and then connect to the BlynkMe-4-digit-color-code that shows up in the app. Is this a brand new Blynk board or is it possible someone has already claimed the device?
You can also try [reconfiguring your Blynk board by following the instructions in that link. If that does not work, you could try setting up your Blynk board to work with Arduino following [this guide and after that, re-install the [Blynk Core Firmware to restore it to factory defaults.](Blynk_Board_ESP8266/Firmware/BlynkBoard_Core_Firmware at master · sparkfun/Blynk_Board_ESP8266 · GitHub)](Blynk Board Arduino Development Guide - SparkFun Learn)](Getting Started with the SparkFun Blynk Board - SparkFun Learn)](Getting Started with the SparkFun Blynk Board - SparkFun Learn)
