I am new with coding, and the Blynk Board seemed to be the most simple option. The Blynk Board claims to be a 5-10 minute process of connecting the board to WiFi then dragging and dropping icons to “code” the board. The RGB led will blink pink/purple which alerts that a device is connected, but I will try to send the WiFi credentials to the board, and it won’t even try to connect. I am working on a project for school, so any help would be appreciated.
Do you ever get a 4 blink pattern when you power up the board? Something like red,green,purple, blue or red,red,purple, yellow? (order of the colors don’t matter.)
Yes I do get the 4 color pattern.
Alright, did you then connect your phone to the Blynk Board’s WiFi network and then use the Blynk app on your phone to provision the board?
Yes I have done that already.
I have gotten a little bit farther. I come to this screen for Sparkfun Blynk Board Configuration. I fill it out and I just copy the auth token and paste into the form, but there’s an error notification every time saying “Please match the requested format”
