Greetings! I am new to the forum and just wanted to throw this question out there. I would like to connect a 10DOF IMU to an Arduino board that is connecting to servos but don’t know what boards are the most compatible. Any suggestions?
What are you looking to do with the IMU ? How many servos ? Do need any other I/O ?
I would like to use the IMU as a motion controller to control the position of at least four servos.
It’s claimed that even an Uno can control up to 12 servos with only minimal resource usage. Then again I note a Mega2560 is what’s used for the latest 9 DOF Ardupilots. I didn’t think there was much (if any) of a computational capacity difference btw the two. The Mega just has more built-in peripherals and memory. Either should work is my GUESS, your choice.
Do you know of any code that has already been written to do this? Or maybe enough code to get started? Thanks for your help.
To do this ? What’s this ? I might guess you mean something like (perhaps w/o the wireless) this:
http://www.youtube.com/watch?v=gg9fjr_A4ts
Google IMU, robotic arm, controller or the like. I’m sure there’s dozens of open source projects w/code for you to peruse.
