Hello Spark Fun Team,
Recently purchased (less than 30-days and just got around to setting it up) a RTK Surveyer and the Facet L-band to test out (trying to replace some SP 80 and Carlson SurvCE gear)
I was able to get the Surveyor charging, but while i was setting up the keys on the L-band and getting it squared away while it was plugged in it apparently wasn’t charging. I left it overnight and was surprised that it still had 6% when I went to turn it on. Then i saw the green LED light wasn’t on. I tried two different cable configurations and nothing. Looking at the post where the guy shoved it in roughly didn’t work either. Nothing looks obviously broken from the outside but I am not an electronics expert. Taking it apart would likely not tell me much unless i knew exactly what it should or shouldn’t look like.
Got it from Amazon and talked with Joelle who said to post here. Attaching pictures of its ID and the lack of green LED.
Can I returned it to be fixed or is a replacement from Amazon easiest.
