Breakout Board for FT232RL
New and confused here. Regarding the Breakout Board for FT232RL; the title says USB to serial, but the description states USB to UART. There is a difference right? USB to serial will require a MAX233 while USB to UART can connect directly to the TX RX of a micro processor? Also this part is powered via the 5v USB and the 3v is just a power out, correct?
lanamor:
While you see the Breakout board, the best approach would be to study the Datasheet of FTDI’s FT232Rl
most of your confusions/clouds would be cleared off.
Thanks for that “teach a man to fish” answer. I found my answer at para 7.4. The FT232RL connects directly to the MCU.
lanamor:
Sincerely, I am happy that you got the solution to the issue(s). All the best.
