Broken Wall Adapter Power Supply - 5VDC, 2A (Barrel Jack)
I bought a Wall Adapter Power Supply - 5VDC, 2A (Barrel Jack) from:
https://www.sparkfun.com/products/15312
and it outputs 5.25 V, but as soon as a load is applied that needs around 300 mA, the voltage drops below 4 volts and jumps around. Consequently, the motor does not work.
Thank you.
Hi user81.
Yeah, that does sound like a bad adapter. Sorry about that!
Go ahead and fill out the return form [on this page with your order number and let us know you need a replacement and we can get that taken care of for you. :-)](Return Policy - SparkFun Electronics)
Thank you. I have submitted a RMA.
OK, thanks for doing that! A replacement is on the way. :slight_smile:
