Can I replace the TIP3055 transistor by the 2N3055?
Hello!
I am doing a project that will use TIP3055 transistors, after reading a detailed introduction article about this device, here’s the link: [TIP3055 Datasheet
But my local shop is almost out of TIP3055 transistors…
They just have a lot of 2N3055 in stock.
But I wonder if I can replace the TIP3055 by the 2N3055?
Thanks!](https://www.apogeeweb.net/circuitry/tip3055-npn-transistor-equivalent-datasheet-pinouts.html)
Depends on your situation, but the housing is different…
http://www.incbtech.com/index.php/artic … 055-ip165e
Mouser has a few hundred TIP3055 in stock.
The 2N3055 is a TO-3 package, while the TIP3055 is a TO-247. They are very different.
thanks mate, really helpful!
