Can the RTK EXPRESS be modified or upgraded to have IMU and L band function?
You could use this https://www.sparkfun.com/products/19390 and a choice of IMU https://www.sparkfun.com/categories/160 to add in those features ![]()
If using qwiic for both make sure you disable all but one set of pull up resistors
In short, the RTK Express is not upgradable to L-Band. TS-Russell is correct, you could add the NEO-D9S breakout over Qwiic but I’m not sure if the firmware on the RTK Express would identify it correctly. Additionally, adding an IMU would be a very large change to the system that is not possible at this time.
