does anyone have advice on how to do this or if it’s possible? if not, any suggestions on what type of button would work on a very simple paper circuit?
Also, is the side with the S positive or negative?
THANK YOU!
THANK YOU!
Hello india!
Yes, that should work as long as you’re using the copper tape that has [conductive adhesive. :-)](Copper Tape - Conductive Adhesive, 5mm (50ft) - PRT-13827 - SparkFun Electronics)
