hi,
I had been working with IMU 6 DOF- v2 with Bluetooth/ADXRS401.
I connect it with no problem. I’m able to modifie sensor range, output type and channel list.
Every time I run it and later try to stop it. I can’t. SpaceBar does not work. After a while the terminal stop and the IMU continue blinking as it keep working when I lost conexion and I had to reset the IMU and reconnect to get it back.
I don’t know where is the problem, Is it my keyboard configuration? (I try with hyper terminal, putty, reflexion, sendind spacebar character (32 ascii). Is it the bluetooth configuration, PIC, …?
If anyone had this problem before or know how to fix, or have an idea, please tell me!!!
