Hi
I was upgrade firmware on F9R from HPS1.0 to HPS1.2(FWVER=HPS 1.20 on UBX message)
But can’t configure L1S option in U-center(grayout in GNSS configuration/ACK-NAC receive after Send configuration message.)
It’s can configurable on release note in HPS1.20
"CFG-SIGNAL-QZSS_L1S_ENA Configuration item to enable QZSS L1S support "
refer : https://www.u-blox.com/sites/default/fi … 102%29.pdf
U-center’s version is 21.05. Integrated protocol filter seems as not support HPS 1.20.
Can I send raw hex configuration data to GPS module? or Is this any solution for fix this problem?
Finally.
“U-block’s customer support not provide support for user” So, anyone should not choose u-block product except for play purposes !!!"
