What are the recommended charging parameters for a nominal 12V LiFePO4 battery to be charged with your product PRT-10473?
Thanks and regards
Thanks and regards
Hello gromit.
Unfortunately I don’t have any data on your battery so I can’t tell you what settings to use, but the [user manual for the charger might help. LiFe would be the battery type you need.](https://cdn.sparkfun.com/datasheets/Prototyping/IMAX-B6.pdf)
