Hello to everyone!
I would like to know what is the nominal output current and what is the nominal charging current of the subject battery.
Hello to everyone!
Hi drcco,
Unfortunately, we do not have a datasheet for this battery so we do not have specific values from the manufacturer for the nominal charge and discharge current. That said, this battery comes from the same supplier as our other single-cell LiPo batteries so the material composition should be the same and according to the datasheets we have for other batteries like this [ 850mAh battery the nominal charge and discharge current is 0.2C so for the 2Ah that would be 400mA. You’ll probably be just fine with a standard 500mA charge and discharge rate as well. The max charge and discharge for any of these batteries is 1C.
I hope this answers your question thoroughly. If you have any other battery-related questions, please reply to this thread and we’d be happy to help.](https://cdn.sparkfun.com/datasheets/Prototyping/850mah-en-1.0ver.pdf)
Hi TS-Mark,
Thank you for your reply. The information you provided are very useful.
