Hello guys,
i need help for choosing the right chip/module with dev board:
Here my guidelines:
WLAN coexistence with AWMA [802.15.2, Clause 14.1]
3 weeks ago, when i started with my quest, i had 5 to 6 chips in my shortlist. After checking the aivailability, minimum purchuse and cost there was only the CSR BLueCore which was left over.
10 minutes ago, i read:
Finally the most important is the xIDE BlueLab 4.1 which is include IDE and C compiler and DSP Assembler, which you need to manage to find it.
Because without BlueLab you cannot develop you software for Virtual Mode application, you will need this software to compile your C code and merge it with the CSR bluetooth stack firmware signed or unsigned is depend on you, how you want to protect your design or not.
Link: viewtopic.php?t=16425
Here is my list which got of of line:
Free2Move F2M03GLA → not in FW integrated
Infineon PMB 8753/2 SPP-AT → only bulk
TI BRF6300 → only OEMs
Philips BGB210 -->sold to ST/Ericsson
LMX 9830 SM-ND → no WLAN coexistance
CSR Unifi CSR6026/6028 → no BT2.0
Mitsumi WML-Cxx → no WLAN coexistance
I was looking forward to buy @digikey an DEV-SYS-0115-1A BC6-ROM QFN Modul.
Is it necessary to buy a BT Developer lisence or an CSR-BCES01 CASIRA Developmenttool when i’am going to programm that chip?
Does that mean the compiler etc costs that much?
My apprehension is increaded by follwing:
SDKs include firmware and software libraries for Bluetooth profiles and the application
Link: http://www.csr.com/store/search.php?q=id
“DL-BDEV-10002-1A”
Does anyone have another idea or referance?
It would give me great pleasure!
Thank you very much,
regards
