Greetings,
I’m trying to connect the[ 3-coin acceptor to a RaspberryPi. I have a 12v power supply for the acceptor and a separate 5v supply for the pi. I believe, if I read correctly, that the COIN pin pulls to ground for coin acceptance pulses, but I don’t understand if this will read as ground for my pi, or pose any danger to it, and I’d prefer to not fry it finding out. Is this signal readable (are the ground values the same) or should I have some sort of interface between them to “step-up/down” the ground to the correct signal for the pi?
Thanks](Coin Acceptor - Programmable (3 coin types) - COM-11719 - SparkFun Electronics)
