Hi there,
I want to combine my own custom made libraries into a single library. How do you that? Thanks
smdfan
Hi there,
smdfan
There might be something easier, but this is the easiest way I know to copy whole parts.
Open the main library you want to use. Go to the control panel window and use the library tree to expand the libraries you want to copy from. Right click on each part you want and select ‘Copy to Library’. This copies the part to the currently open library.
