Config error: INS: unable to initialise driver
Hi there -
I received a new Holybro pixhawk 4 and attempted to flash/configure it with QGround Control using Rover 4.0.0.
Unfortunately the message the pixhawk keeps spitting out is
I flashed it with other versions of the firmware (rover 4.1, plane etc) but to no avail - the message remains the same.
Any advice to offer ?
You could try resetting the USB drivers (if that’s how you’re connected)
You can also check the board debug status using the steps outlined here https://docs.px4.io/master/en/debug/system_console.html and see how that goes :slight_smile:
