Hi all,
Hope this question hasn’t been answered yet. I wasn’t able to find it here or in google so maybe someone can help.
Perhaps I’m just being lazy but I need to add nets to some large multi-pin connectors a lot like this:
https://drive.google.com/file/d/0B4ncRl … sp=sharing
And ultimately they should look sorta like this:
The second one I did by creating a group and copying but none of the nets are actually connected.
The connector shown is just an example though, the actual connectors I will be using have 68 pins, so you might could imagine how much of a hassle it would be to connect all those nets manually.
I thought that I accidentally found something that would auto-connect parts but i wasn’t able to reproduce it.
Basically I’m just trying to see if there’s some build in function that will auto connect pins of the same name.
I suppose using the “names” could help?
Any way, any help is appreciated!
-D
