Connecting GPS Mini (MN5010HS) to RS232
Hi All,
I recently purchased a GPS-Mini and would like to connect it to an RS232. Can somebody support me in that ?
Thanks all you in advance any help.
For everybody that have that same problem. Is is very easy and works fine, just be carefull to have stable +5v on Vcc pin ( I have used LM2931 )
http://sodoityourself.com/max232-serial … converter/
In the link above they have used ceramic capacitors, instead I have used electrolitic capacitors.
