Copying Components between schematic in Eagle 5.2.0
Is there any way I can copy components between two different schematics?
The part is not in the library. Tried to use the Copy command but it won’t let me Paste in the new sheet.
In eagle, the cut command does what you usually expect the copy command to do.
