whenever i boot my cs-e9302 the time and date is in past (1970).
each time i set system time and hwclock manually.
so how can i keep the time correct even if i remove the power? it should be a battery, isnt it?
This board AFAIK do NOT have hardware clocks and battery for it… So, configure manually each time ![]()
Or configure Linux on your board to sync from the time server ![]()
