I am using a servo trigger. I am looking for something I can use to electronically activate the trigger. I want a device that will recognize that I have started a 120v machine and then activate the trigger.
Skip…
Skip…
We don’t carry a ‘plug and play’ solution for the problem you’re wanting to solve but a current sensor like SEN-11005 along with some signal conditioning components could be used to toggle a relay that would command the Servo Trigger to change states.
What ever you do, DON’T plug SEN-11005 directly into the Servo Trigger, that will damage the board.
