I am trying to control a fan and two relays on a timer. I want to use a plug like this https://www.primecables.ca/en/p-368982- … #sku381085 that has one wifi outlet and one normal outlet. I want to use the normal outlet to provide the power to the servos then run the fan off the other outlet. Then I can use the app for controller the outlet to set a timer for the fan. I want the servos to open blast gates so that air only comes in when the fan is running.
My question is, is it possible to have the servos open when power turns on to the fan and then close when the power goes off? I was looking at the sparkfun servo trigger board but not sure if that would work for me. Any help would be greatly appreciated!
