Hi, I am a novice at electronics and need some assistance in hooking up a 6V servo, set positions A&B, switch from A to B and back again as per the Trigger Board . Is there a method to supply a servo motor at 6V from separate power supply from the one powering the Servo Trigger board? :oops:
Yes, connect the ground for the servo, the ground for your 6 volt power source and the ground for the servo trigger together.
Connect the positive for your 6 volt power source to positive on the servo.
Connect signal on the servo trigger to signal on the servo.
