I’m trying to connect 2 of the 581 pressure sensors to the serial port, but it seems to recognize only one?
Did you change the I2C address on the second sensor?
Also, it’s helpful to put the sparkfun part numbers in your post.
I’m using the DEV-20594 Datalogger 9Dof and the Sen-20170 BMP581(two of them) pressure sensor; I’m not sure how to change the address. Can you tell me where I can get the information?
Hookup guide has this information.
https://learn.sparkfun.com/tutorials/qwiic-pressure-sensor-bmp581-hookup-guide
Look for the section on solder jumpers.
