Hello there,
Is there any way to enable SSH on the DataLogger IoT to configure it remotely once it connects to WiFi?
I did the initial configuration and setup over USB, but I was wondering if an SSH option could be added/enabled.
Hello there,
Not currently…though there is ‘secure MQTT’ https://docs.sparkfun.com/SparkFun_Data … ure-client and HTTPS https://docs.sparkfun.com/SparkFun_Data … tion-setup
The source code is here https://github.com/sparkfun/SparkFun_Da … r/releases if you want to customize it…though I can’t offer much advice in that realm
