Defective 24MHz crystal on teensy 4.1 board
I recently got a teensy 4.1 from sparkfun. It works sometime, but after a while (few minutes) it stop responding and the board gives me 9 blinks.
If I restart the board after that, I get 4 blinks which seem to point to “ARM JTAG & SWD Not Responding (Needs Crystal)”.
Measuring the signal at C1 (Teensy® 4.1), I do not see the 24 MHz signal when the board is in this state (when the board is in a working state, I clearly get the 24 MHz signal).
Is the Y1 crystal defective?
It sounds like it; I found your order and will get a replacement sent out ASAP
Hello TS-Russell, I recently purchased a Teensy 4.1 from SparkFun, and am experiencing the same issue(s). Initially, the board worked, but then went into 4-red-blink mode. There was once instance when it did 9-red-blinks, but it’s been consistently 4-red-blinks otherwise. I’d be happy to send it back, if a replacement is possible.
Was it purchased from us? If so head over to Return Policy - SparkFun Electronics (contact vendor if purchased elsewhere) and we’ll get ya squared away
@TS-Russell yes, it was through your website. Thank you for the link, I initiated a refund. Would you be interested in having the unit back, to investigate? I have since ordered and received another, which is installed in my project and working without any hiccups!
The CS rep will give any relevant instructions hereforth :slight_smile:
I’m seeing this too. Teensy 4.1 is part of a product we manufacture. One of the units was working and then suddenly bricked with a crystal failure - 4 flashes, no startup or response to button press. I hope Sparkfun will look into this. PJRC had incredible production quality and we need that to continue under Sparkfun - we can’t have our boards failing in the field.
Sorry to hear you got unlucky…though there are always going to be some amount of defects; even the Raspberry Pi stuff which gets fully QC-verified and tested at production show 0.5-2% failures. SparkFun sells “hobby-grade” products…if any risk of failure is catastrophic for your use you might need to look at “industrial” MCUs/products
We offer a 30-day no questions guarantee for situations where boards are deemed defective if that applies
