I want to build a GPS data logger and am looking at the KIT-24056 Sparkfun DataLogger Iot GPS Kit ($99.95).
I want to input a meter via its USB-A that typically connects to a PC (where I read the values), but I want to route it into the Sparkfun DataLogger so it can stamp a GPS on it and save to the SD card.
Id like to do with with a QWIIC adapter board.
Is there a QWIIC board that accepts a USB-A input that I can then attach to the Sparkfun DataLogger + GPS.
I have scoured the Site but have not found this.
Dronefiledrop
Dronefiledrop@gmail.com
No
We started adding qwiic connectors around the same time that we swapped to using usb-c (there are a few exceptions, but those use micro usb & qwiic…not usb-a)
We do have an adapter https://www.sparkfun.com/products/21870 so you could use any usb-c boards
Or you could combo a mix of these
https://www.sparkfun.com/products/14495
https://www.sparkfun.com/products/15100
https://www.sparkfun.com/products/14425
Thank you very much for the quick (qwiic?) reply. Can you please confirm that if I plug in a meters output to the the Datalogger board’s USB-C port,
it will accept serial input and write it to the SD card along with the corresponding GPS stamp?
After looking more: I don’t see anything that mentions logging data from the usb port https://docs.sparkfun.com/SparkFun_Data … ial-output (using usb as serial INput)…
…but you could likely make some adjustments to the firmware https://github.com/sparkfun/SparkFun_Da … r/releases
It might be simpler to use something like https://www.sparkfun.com/products/15096 and have it pass the data over to the PTH pins on the datalogger instead
