mbyron
1
I just purchased one and it did not work when connected. I am assuming that I need a driver for it.
I went to the site as per your recommendations for the product to get a driver.
the site is https://www.ftdichip.com/FTDrivers.htm . I could not find a driver for the FTDI FT231X that is used on this breakout.
How do I get the driver?
HI mbyron,
You just need to download the driver from [this page for whichever Operating System you are running. That will install the VCP and D2XXX drivers for the Beefy FTDI Breakout. If you have any issues with that install, FTDI has extensive Installation Guides for various operating systems [here.](https://www.ftdichip.com/Support/Documents/InstallGuides.htm)](https://www.ftdichip.com/Drivers/VCP.htm)
