DEV 20594 9DoF IOT Board
Is it possible to trigger the DEV-20594 board to record data after being triggered to do so as opposed to its normal mode of operation, which is to record continuously when plugged into power? I looked at GitHub thinking I could edit the existing firmware, but the firmware is already compiled into binary. Is there any chance of getting the source code in its original format?
Hi Sparkfun,
I’m also keen to see the source code for this board? I’d love to learn a bit from how you’ve written the code. You have a couple of links to the source code on the Github Releases page https://github.com/sparkfun/SparkFun_Da … r/releases but they only contain the bin files and some doco, unless I’m missing something? Thanks, PJ
