Did I fry my atmega32?
I got a program working last night in my board and tested the ports. One pin wasnt working so I took a closer look at the soldering. I tested the pin and it wasnt soldered properly but it was only one pin so it doesnt really matter.
When I reconnected the board to the PC and tried programming it again - nothing worked. I cannot get anything from the ports anymore. I did a READ PROGRAM (flash) and ponyprog and I get all these BFs! Did I fry the chip? When I do an erase and then read the chip there are BFs all over like a virus.
What do you think?
sorry, not enough info.
I’ve been pretty abusive with mega’s and they’ve survived.
So check the obvious - cables/connectors/plugs/bent IC pins, etc.
