Difference between CCE and (MSPGCC + Eclipse IDE + GDB)
I will like to know which are the fondamental difference between Code Composer Essentials and the GNU Compiler (MSPGCC + GDB + Eclipse IDE)
Because CCE is based on Eclipse IDE + GDB !?
That is really equivalent and which are the limitations ?
Thanks.
Best regards
Vincent
I’m french and i’m sorry for my english. It’s not perfect. :oops:
I think an immediate difference is that, GCC is free.
Code composer costs! For the download version, there is a 8KB limitation in C coding.
There may be certain optimization levels between the two compliers for sure.
But I just don’t know which one is better.
John
Thank you John !
