I’m using your DYScan DE2120 scanner module in a machine, but it’s very space constrained. Can I safely separate the black housing with the sensor and lights, from the PCB? I’d still keep the ribbon connected but it would make it easier to mount it if I could split them apart.
Yep, you sure can ![]()
