I make a huge amount of prototypes for the work I do. Most will be one offs for testing ideas. Having been turned on to the hot plate technique, I wonder if there is better way to join the top and bottom traces than just lacing a thin tinned wire through them. The holes are small so eyelets won’t work. Any good ideas out there?
Oh, I use Eagle for the layouts. This brings up a second question…Is there a way to make the trace widths smaller? .010 is the thinnest it appears one can go, but is there a way to change that?
