Hi, I have a DRC drill size error in my via’s that reads - Errors (4) drill size, layer 20. All four of these DRC errors are for the drill size for the via’s I inserted. I cannot find the solution to rectify this problem, any help or direction would be appreciated!
Stan
              I would click on the little spanner/wrench icon in the board editor, go down to drill and select a drill size that
will go through you Drc, then click on the via’s that are acting up and they will change…
(but how have you put via’s on the Dimension layer? I thought that wasn’t possible nor wanted :? )
                bigglez
                    November 17, 2008,  8:30am
                  3
jonathan3233:
What toolchain are you using? (Sounds like EAGLE).
If so, what EAGLE version?
FartingMonkey92:
Yes, that did it - Thanks!
Don’t know how I put the via’s on the dimension layer, when I ran the DRC and turned off all the layers except layer 20 as shown by the DRC window
there they were, I suppopse anything is possible when I get frustrated. :roll:
I was using Eagle 5.3.0 light.
